Salta al contenuto principale
Brentwood TS-292B Browning Dial Circuitboard Replacement
Cosa ti serve
  1. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: passo 1, immagine 1 di 3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: passo 1, immagine 2 di 3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: passo 1, immagine 3 di 3
    • Remove the five screws indicated using a Philips head screwdriver.
  2. Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 2, immagine 1 di 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 2, immagine 2 di 2
    • Pull hard on the browning lever until it detaches from the toaster.
    • It will take some force to pull it off.
    • Once the tab is off, lift up on the housing to remove it from the toaster.
  3. Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 3, immagine 1 di 1
    • Once the housing has been pulled upwards, carefully uplug the wire connecting the browning dial circuit board to the main circuit board.
  4. Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 4, immagine 1 di 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 4, immagine 2 di 2
    • There are four screws on the circuit board for the browning dial.
    • Unscrew each of them with a Philips head screwdriver to detach the board and remove the board and dial from the toaster housing.
  5. Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 5, immagine 1 di 2 Brentwood TS-292B Browning Dial Circuitboard Replacement: passo 5, immagine 2 di 2
    • There are two holes on the board where the pin from the browning dial can align.
    • Refer to the images if you are having trouble finding them.
    • Replace the browning dial by inserting the pin on the dial into one of the holes indicated.
    • Replace the entire circuit board if need be.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 239
