Salta al contenuto principale
Brentwood TS-292B Bread Grabber Spring Replacement
Cosa ti serve
  1. Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: passo 1, immagine 1 di 2 Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: passo 1, immagine 2 di 2
    • Turn the toaster upside down.
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
  2. Brentwood TS-292B Bread Grabber Spring Replacement: passo 2, immagine 1 di 2 Brentwood TS-292B Bread Grabber Spring Replacement: passo 2, immagine 2 di 2
    • Grasp the plastic pull lever cover firmly and pull to remove it. This may require force.
    • Lift the cover upwards to remove it.
    • When removing the cover, do not damage the cable connector bundle that attaches the cover to the toaster.
  3. Brentwood TS-292B Bread Grabber Spring Replacement: passo 3, immagine 1 di 1
    • To detach the bundled cable connector, carefully pull it away from the circuit board.
  4. Brentwood TS-292B Bread Grabber Spring Replacement: passo 4, immagine 1 di 2 Brentwood TS-292B Bread Grabber Spring Replacement: passo 4, immagine 2 di 2
    • Pull the toaster lever down.
    • While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
    • Continuing to hold the toaster lever down, pinch the wires inward and pull up to carefully remove them from the toaster.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 388
