Salta al contenuto principale
Braven BRV-1s Speaker Cone Replacement
Cosa ti serve
  1. Braven BRV-1s Speaker Cone Replacement, Outer Casing: passo 1, immagine 1 di 1
    • To remove the outer case, remove 4 phillips screws (Phillips #00 headtype, 9.3mm long)
  2. Braven BRV-1s Speaker Cone Replacement: passo 2, immagine 1 di 1
    • Using a metal spudger, gently pry the side of the defective case.
  3. Braven BRV-1s Speaker Cone Replacement: passo 3, immagine 1 di 1
    • Still using the metal spudger, continue to work your way around the outer case.
  4. Braven BRV-1s Speaker Cone Replacement: passo 4, immagine 1 di 1
    • Remove the broken outer case. Replace with used/new out case.
    • Note that unless properly sealed with glue, the speaker will no longer be water resistant.
  5. Braven BRV-1s Speaker Cone Replacement, Speaker Cone: passo 5, immagine 1 di 1
    • To remove the speaker cone plate, remove 10 phillips screws (Phillips #00 headtype, 9.3mm long)
  6. Braven BRV-1s Speaker Cone Replacement: passo 6, immagine 1 di 1
    • Using a metal spudger, gently pry the side of the defective speaker cone plate.
    • Remember to pry all around the side of the speaker cone plate.
    • Keep in mind that the adhesive will make it difficult to pry the plate off. To loosen the adhesive, heat the plate with a device such as a hair dryer.
  7. Braven BRV-1s Speaker Cone Replacement: passo 7, immagine 1 di 2 Braven BRV-1s Speaker Cone Replacement: passo 7, immagine 2 di 2
    • Remove the broken speaker cone plate. Replace with used/new out plate.
Conclusione
Leanne Abel
Membro da: 03/06/17
101 Reputazione
1 Guida realizzata
IUPUI, Team S2-G2, Harley Spring 2017 Membro di IUPUI, Team S2-G2, Harley Spring 2017
IUPUI-HARLEY-S17S2G2
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 734
