Salta al contenuto principale
Braven BRV-1s Motherboard Replacement
Cosa ti serve
  1. Braven BRV-1s Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Braven BRV-1s Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Using a 0mm Philips Head screwdriver, unscrew the four 0.9mm screws located on the bottom of your device.
  2. Braven BRV-1s Motherboard Replacement: passo 2, immagine 1 di 2 Braven BRV-1s Motherboard Replacement: passo 2, immagine 2 di 2
    • Take a metal spudger and insert it into the bottom seam.
    • Work the spudger around the bottom seam making sure that bottom of the speaker is no longer glued onto the rest of the speaker.
  3. Braven BRV-1s Motherboard Replacement: passo 3, immagine 1 di 1
    • Pry upward on the spudger until the bottom of the speaker is removed.
    • This is very difficult. Be sure to pry with care and avoid prying towards yourself. You will want to pry away from yourself in case the metal spudger suddenly becomes loose.
  4. Braven BRV-1s Motherboard Replacement: passo 4, immagine 1 di 1
    • Underneath the bottom of the case you will find the speaker driver, also known as a woofer.
    • Using a 0mm Philips Head screwdriver, unscrew the 0.6mm 10 screws located around the outside of the woofer.
  5. Braven BRV-1s Motherboard Replacement: passo 5, immagine 1 di 1
    • This area is glued down as well. Use a heat pad or other heating device if needed.
    • Insert the metal spudger between the seam of the woofer.
    • Work the spudger around the seam to loosen the woofer and get rid of excess glue.
  6. Braven BRV-1s Motherboard Replacement: passo 6, immagine 1 di 1
    • Pull upward on the woofer until it is removed.
  7. Braven BRV-1s Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the foam padding located in the Braven BRV-1s.
  8. Braven BRV-1s Motherboard Replacement: passo 8, immagine 1 di 1
    • Using a 0mm Philips Head screwdriver unscrew the three 0.6mm screws on the motherboard.
  9. Braven BRV-1s Motherboard Replacement: passo 9, immagine 1 di 1
    • Push the motherboard via the outer auxiliary ports out of the speaker.
    • You may wish to use a tool to push the circuit board out via one of the auxiliary ports.
  10. Braven BRV-1s Motherboard Replacement: passo 10, immagine 1 di 1
    • Soldering irons get extremely hot. Be sure to wear proper protective wear and keep it away from exposed skin while it is turned on.
    • Turn your soldering iron on to high.
  11. Braven BRV-1s Motherboard Replacement: passo 11, immagine 1 di 2 Braven BRV-1s Motherboard Replacement: passo 11, immagine 2 di 2
    • You may wish to use a heat gun to melt any excess glue that may be holding the wires down.
    • Using the soldering gun, desolder the wires off the motherboard.
  12. Braven BRV-1s Motherboard Replacement: passo 12, immagine 1 di 2 Braven BRV-1s Motherboard Replacement: passo 12, immagine 2 di 2
    • You can also just pull up this circuit board carefully; it is easier if you scrape off the glue that is holding it to the posterior frame (arrow)
  13. Braven BRV-1s Motherboard Replacement: passo 13, immagine 1 di 1
    • Once you have soldered off the wires, remove by pulling upwards.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
To reassemble, use reverse order??? WHAT ABOUT THE GLUE TO RETAIN WATERPROOFNESS??? WHAT TYPE OF GLUE? HOW/WHERE DO YOU APPLY IT??
horse_06 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,280
