Salta al contenuto principale
Braven BRV-1M Sub-woofer Cone Replacement
Cosa ti serve
  1. Braven BRV-1M Sub-woofer Cone Replacement, Sub-woofer Cone: passo 1, immagine 1 di 1
    • To remove the outer rubber casing use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides, found on the bottom part of the device.
  2. Braven BRV-1M Sub-woofer Cone Replacement: passo 2, immagine 1 di 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Sub-woofer Cone Replacement: passo 3, immagine 1 di 1
    • To remove the hard inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the subwoofer on the top side of the device.
  4. Braven BRV-1M Sub-woofer Cone Replacement: passo 4, immagine 1 di 1
    • Carefully lift away the broken sub-woofer plate of the device. Replace with functioning sub-woofer plate.
Conclusione
Erik Oliva
Membro da: 02/14/18
607 Reputazione
6 Guide realizzate
USF Tampa, Team S2-G1, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 171
