Introduzione
A crack or damage found on the front screen of the speaker can cause distorted or washed out audio. This guide can be used to learn how to properly remove and replace a broken front speaker screen.
Strumenti
Parti
Nessuna parte richiesta.
  1. To remove the front speaker screen, unscrew the 10 Hex 3mm bit type, 9mm long screws surrounding the screen.
    • To remove the front speaker screen, unscrew the 10 Hex 3mm bit type, 9mm long screws surrounding the screen.
  2. Gently lift away the front screen from the device.
    • Gently lift away the front screen from the device.
    • A Plastic Spudger may be needed if one cannot find a proper grip.
Conclusione
Erik Oliva
Membro da: 14/02/2018
607 Reputazione
6 Guide realizzate
USF Tampa, Team S2-G1, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Membri
6 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 16
