Salta al contenuto principale
Braun Series 7 790cc-7 Charging Base Wire Harness Replacement
Cosa ti serve
  1. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement, Charging base wire harness: passo 1, immagine 1 di 1
    • Remove the cleaner cartridge from the charging base.
  2. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 2, immagine 1 di 3 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 2, immagine 2 di 3 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 2, immagine 3 di 3
    • Depress the 4 tabs while lightly pulling the cover from the base.
    • Next, depress the 2 molded tabs while still pulling the cover from the base.
  3. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 3, immagine 1 di 1
    • Press inward on the side charging port while pulling cover from the base to separate.
  4. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 4, immagine 1 di 2 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 4, immagine 2 di 2
    • Remove side charging port by prying tabs outward and rotating port upward.
  5. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 5, immagine 1 di 2 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 5, immagine 2 di 2
    • Remove charging terminals by inserting a spudger from bottom the and sliding terminals up.
  6. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 6, immagine 1 di 2 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: passo 6, immagine 2 di 2
    • Remove solder from circuit board and remove charging harness.
Conclusione
Ian Hayes
Membro da: 11/07/17
246 Reputazione
2 Guide realizzate
IUPUI, Team S3-G6, Harley Fall 2017 Membro di IUPUI, Team S3-G6, Harley Fall 2017
IUPUI-HARLEY-F17S3G6
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,208
