Introduzione
This Braun Satin Hair 3 hairdryer is disassembled to the point one can easily reach the electronic parts. No soldering is needed to reverse this guide. However, this also means this guide does not describe any repairing of the electronic parts.
Cosa ti serve
Using a Spanner 4.0 screwdriver, unscrew the 1.5mm screw from the exterior of the hairdryer.
Attrezzo utilizzato in questo passaggio:Jimmy$7.95
Begin at the cord end of the product. Gently pry the two halves of the external casing open with the help of a Jimmy and push the front cap up and away from the external casing. The snap-fit should come loose.
After opening the first snap-fit, remove the gray cord protector by slightly pulling it backwards while keeping the gap open with your other hand.
Slide the cord protector down the electrical cord and out of the way.
Attrezzo utilizzato in questo passaggio:iFixit Opening Picks (Set of 6)$4.99
Continue loosening the front cap from the external casing using the Jimmy. The snap-fits tend to snap back in place, so to prevent that use opening picks to keep the separated halves from snapping back closed.
Work your way around the product, opening one snap-fit at a time.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Attrezzo utilizzato in questo passaggio:iFixit Opening Tool$1.99
At the back of the product, the two halves of the case are connected with a snap-fit cap. Loosen this cap by putting a screwdriver or other opening tool under the cap using it as a lever.
Attrezzo utilizzato in questo passaggio:Phillips #1 Screwdriver$5.49
Separate the black inner casing from the other parts by removing the three 1.4mm Phillips #1 screws with a Phillips #1 screwdriver or bit and sliding it off.
Altre 9 persone hanno completato questa guida.
8 Commenti
Thanks a lot. It’s hard to disassemble without cosmetic damage(
Thanks a lot for the great description. I succeeded in repairing my hairdryer. The fan stopped spinning at the highest speed due to hairs caught in it. I removed them. Btw. I used tools for reparing a mobile phone which were very useful. I will add some pictures where I put crosses on the casing just to get an idea where the snap-fit caps are located. It helps to concentrate on these areas. I also succeeded in not breaking the snap-fit cap : )
Thanks! Now "successful"...
Step 5 was essential to me (did it too late), the last snap-fit of the front cap, it removes the whole case...
I repaired a satin hair 5. Afterwards I "flattened" and fitted the edges and grooves with a knife ("round" handle and blade)
Thanks for informing but did not inoformed the the manufacturer put something like glue to seal it bcz they want it not repairable just use it and throw it but I fix it very hardly.only the problem comes some hair caught in the blower I request to the manufacturer please put some type of net on the air intake side.
Thanks
Excellent instructions, Tell me where are the spare parts for this hair dryer?
