Introduzione
Use this guide to learn how to replace your left and right speaker drivers for the Bowers and Wilkins T7 Bluetooth Speaker.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
While squeezing the internal locking mechanism, pull back the terminal.
Repeat this process for the second speaker.
Remove the 7mm screws around the speaker using a J100 Phillips head screwdriver.
There are 4 screws in total around each speaker.
Altre 2 persone hanno completato questa guida.
2 Commenti
Where do you buy the replacement driver?
Tôi có cùng một câu hỏi? Tôi sẽ phải mua chúng ở đâu.
