Introduzione
A friend donated his P5s whose left channel had died (like mine). I was able to use his working right driver on the left side.
Cosa ti serve
The drivers are inconveniently glued in place, but can be relatively easily removed with some elbow grease.
I used an iOpener to soften the glue, along with a Jimmy and metal spudger to score the glue around the circumference.
Each driver area has a cutout section, as indicated, which will assist you with prying out the driver.
Try to work the driver out only by its sides. I pushed my metal spudger underneath and pried upward and damaged the driver grille.
To reassemble your device, follow these instructions in reverse order and solder the new driver back in place.
