Salta al contenuto principale
Bose Soundlink Revolve Top Circuit Board Replacement
Cosa ti serve
    1. Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: passo 1, immagine 1 di 2 Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: passo 1, immagine 2 di 2
      • Flip speaker over so that the bottom is facing up.
      • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
      Chiedi a FixBot
      Aggiungi Commento
    2. Bose Soundlink Revolve Top Circuit Board Replacement: passo 2, immagine 1 di 3 Bose Soundlink Revolve Top Circuit Board Replacement: passo 2, immagine 2 di 3 Bose Soundlink Revolve Top Circuit Board Replacement: passo 2, immagine 3 di 3
      • Using the screwdriver, unscrew three screws.
      • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
      Chiedi a FixBot
      Aggiungi Commento
    3. Bose Soundlink Revolve Top Circuit Board Replacement: passo 3, immagine 1 di 2 Bose Soundlink Revolve Top Circuit Board Replacement: passo 3, immagine 2 di 2
      • Remove the screw that is above the charging port.
      Chiedi a FixBot
      Aggiungi Commento
    4. Bose Soundlink Revolve Top Circuit Board Replacement: passo 4, immagine 1 di 2 Bose Soundlink Revolve Top Circuit Board Replacement: passo 4, immagine 2 di 2
      • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
      • Remove the bottom cover.
      Chiedi a FixBot
      Aggiungi Commento
    1. Bose Soundlink Revolve Top Circuit Board Replacement, Top Circuit Board: passo 5, immagine 1 di 1
      • Using your hands, grip and separate the soft plastic and the metal casing away from each other with some small force.
      Chiedi a FixBot
      Aggiungi Commento
    2. Bose Soundlink Revolve Top Circuit Board Replacement: passo 6, immagine 1 di 1
      • Remove the (4) four screws shown around the top of the inside.
      • (2) two of the screws are shown here, the other side will look the same.
      Chiedi a FixBot
      Aggiungi Commento
    3. Bose Soundlink Revolve Top Circuit Board Replacement: passo 7, immagine 1 di 2 Bose Soundlink Revolve Top Circuit Board Replacement: passo 7, immagine 2 di 2
      • Pry up and remove the soft plastic casing from the rest of the device.
      Chiedi a FixBot
      Aggiungi Commento
    4. Bose Soundlink Revolve Top Circuit Board Replacement: passo 8, immagine 1 di 2 Bose Soundlink Revolve Top Circuit Board Replacement: passo 8, immagine 2 di 2
      • Remove the 3 screws holding down the top circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    5. Bose Soundlink Revolve Top Circuit Board Replacement: passo 9, immagine 1 di 1
      • Lift up and look on the underside of the circuit board.
      • Using the plastic opening tool, pry open the wide clamp keeping a ribbon to the top circuit board. The top circuit board can now freely be removed from the device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 13 persone hanno completato questa guida.
USF Tampa, Team S6-G2, Remmell Fall 2017 Membro di USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Membri
12 guide realizzate
13Commenti sulla guida
Hello,
I need to buy the TOP CIRCUIT BOARD … Where Can I buy it or could you sell me one ? Thank you my mail is skelet300@gmail.com
skelet300 - Rispondi Condividi
I also need one of these boards and don’t really want to buy a complete used unit to repair mine, copydoc1@aol.com if you know of any resources, thanks in advance.
Jeff Pitt - Rispondi Condividi
Same here. My speaker had one circuit replacement on warranty but now need a second replacement and I not willing to pay half the price of a new speaker each a every year. Can you help please ?
My e-mail is fmtbmp@gmail.com
fmpitschieller - Rispondi Condividi
Hi, I need to buy the top and bottom circuit board and was wondering the same. Any help with where to purchase these would be appreciated,
Thanks, my email is fayclaybrook28@outlook.com
Fay Claybrook - Rispondi Condividi
I am also looking for a top circuit board replacement. Where can I get one. michael@parsche.net
Michael Parsche - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 21
Ultimi 30 giorni: 97
Tutti i Tempi: 15,735
