Salta al contenuto principale
Bose Soundlink Revolve Bottom Circuit Board Replacement
Cosa ti serve
  1. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: passo 1, immagine 1 di 2 Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: passo 1, immagine 2 di 2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 2, immagine 1 di 3 Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 2, immagine 2 di 3 Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 2, immagine 3 di 3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
    These are not the screws I have in my bose speaker. These are standard TORX screws ( with 6 sides) bose uses a special 5 sided secure torx screw(with a dot in the middle of the hole). A screwdriver or a screw-bit for these screws is very hard to find. I am still searching for one
    Frank - Replica
  3. Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 3, immagine 1 di 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 3, immagine 2 di 2
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 4, immagine 1 di 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 4, immagine 2 di 2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: passo 5, immagine 1 di 3 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: passo 5, immagine 2 di 3 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: passo 5, immagine 3 di 3
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
    Where do you buy the usb/ aux port .
    kepac - Replica
    I have a charging cradle and it still flashes red light not charging
    kepac - Replica
    Where do I find this part?
    Bohdan Tomanek (emerysteele) - Replica
    So maybe you have to work at Bose to get the part?
    John Halvorsen - Replica
    Hi! Where do I find this part?
    mariajoseespinoza.m - Replica
    Where can I find this part
    Allan Wilson - Replica
    I just wanted to find out if any android port can be connected and work or they are specific. Also when hot wiring the cables, is there a particular pattern or anything goes?
    Obbo Benjamin - Replica
    How does one reattach the latch here exactly?
    andrewpalozzo - Replica
    Bonjour, ces explications sont très claires mais il reste beaucoup à démonter et surtout on ne sait pas trouver la pièce défectueuse, sans parler d'en trouver une de rechange... Merci quand même mais le chemin est encore long pour réparer cet appareil...
    Henri - Replica
    I suppose if you could open that thing, which might be hard (every smartphone today :D) to impossible without destructing the whole thing (eg Apple usb 3.0 camera adapter) - I haven’t tried it yet -, it’s an easy thing to desolder the ports and replace them with some from eBay or any other platform to buy stuff.
    Daniel Ullrich - Replica
  6. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board: passo 6, immagine 1 di 1
    • Remove the yellow tape over the location where the ribbon from the central speaker meets the bottom circuit board.
    • Use the blue plastic opening tool to pry up the black latch holding down the ribbon.
    • Remove the motherboard from the device.
Conclusione
Altre 5 persone hanno completato questa guida.
Brian Butner
Membro da: 09/27/17
825 Reputazione
3 Guide realizzate
USF Tampa, Team S6-G2, Remmell Fall 2017 Membro di USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Membri
4 Guide realizzate
42 Commenti
I need the ribbon because it is damage, can you sell one to me?
My email is ttegil@hotmail.com can you send me the way I can buy it.
Kind regards
Gilberto - Replica
Hello do toi fond thé ribbon because i have thé same problème .
M'y email adresse thualromain44.rt@gmail.com
Thanks you
romain thual -
Hi I need bottom circuit board for bose revolve , could you sale it for me. mail: seawolf1974@mail.ru , delivery to Spain
kindly regards
seawolf1974 - Replica
I need bottom circuit board for Bose revolve, can I get it available in Nigeria, @sullivaniheme@gmail.com
Sullivan - Replica
Hey there, I also require the bottom circuit board for my Bose Revolve sam.rowlands@hotmail.com
Sam - Replica
Hello Brain. I cannot find were to buy bottom circuit board for bose revolve. Could you sell it for me. mail: gonzser@gmail.com
Thank you
Gonzalo
Gonzalo de la Serna - Replica
Hey Brian I also need the circuit board for the nose revolve and the battery. If you can help me. Thanks my email is lambertjsmith@gmail.com
Jesse - Replica
Hello Brain. I cannot find were to buy bottom circuit board for bose revolve. Could you sell it for me. mail: Rick bull566@aol.com
Thank you
bull566 - Replica
Hi. your guide is great and just what i needed. can you tell me where to purchase a usb port and lower circuit board? thx.
heres my email: andrew.demchuk@yahoo.com
Andrew G Demchuk - Replica
Hi Brain, I also need to replace bottom circuit board for Bose revolve. Can you tell me where to buy it? My mail: bjspeek@live.nl
bjspeek - Replica
Just broke the ribbon connector when taking this thing apart. Do you know where I am able to get a replacement bottom circuit board Brian?
hamishwoyka@gmail.com
hamishwoyka - Replica
Where can I find the bottom circuit board ? Jlorusso24@gmail.com. Thank you!
Jimbo James - Replica
Hello, I too need to buy a new bottom circuit board for the Bose SoundLink Revolve. jaburge1@gmail.com. Thank you!
FunGeorge - Replica
Hi I require the bottom circuit board are you able to provide this item for sale. david_lee24@hotmail.co.uk
David Holmes - Replica
Need to buy board and cable, please. reimao@gmail.com
Pedro Reimao - Replica
Hello Brain.
Could you sell it for me?
mail: fabforrun@gmail.com
Thank you
Fabien
Fabien Clementz - Replica
Hey thank you for the help but where can i buy the bottom circuit board. pls?
My contact slwebuse@gmail.com
regards,
scott
scott - Replica
Hello, do you sell the bottom circuit board for bose? , could you sale it for me: mail: sa_alexandre@hotmail.com, delivery to Brazil. Best regards
sa_alexandre - Replica
Hello i need the bottom circuit board for the revolve Bose
do you sell it ? Or can you tell me where can I get it ? guillermo_alc@hotmail.com
birdcacatua - Replica
Hello, I would also need the circuit replacement board. My email is Jolilum1@gmail.com
Thanks a lot,
Juan.
Jolilum1 - Replica
bottom circuit board link ? I need one as well
Alan.cyr(AT)gmail(dot)com
Alan Cyr - Replica
Hello, I am also looking for the bottom circuit board for Bose Revolve. Thanks, regards, efreibox@hotmail.com
jean - Replica
Hello, as anyone know where we can find the bottom circuit board. Thank you, efreibox@hotmail.com
jean - Replica
kkc6143@gmail.com
kkc6143 - Replica
I am also looking for the bottom circuit board for Bose Revolve. michael@parsche.net
Michael Parsche - Replica
Anyone found where to buy this circuit board?
fmpitschieller - Replica
hello, I’m also looking for the sparepart.Did you get any news regarding where to buy it?
Thanks in advance
marcos tito Elizalde -
hello i have broken the tablecloth on the board where to find it ???
u2forevernow - Replica
Hello, nice tutorial, how to get the item? Can you send one to France? Veens876@gmail.com
veens876 - Replica
Need the bottom circuit board where can i buy it .
Humberto nieves - Replica
Hello, I’d also would like to buy a bottom circuit for bose revolve. Do you know where I could find it ?
Thank you for helping and for your site.
Romain
cornazro@gmail.com
romain cornaz - Replica
Hi Friends,
I got a supplier for original power circuit board but price is not cheap. Is there any that we can direct purchase from Bose?
joytech asia - Replica
Hi thanks for this tutorial, i need the circuit board  for this bose revolve. Do you sell it ?
my mail : gregory@adelios.fr
Thx
G.C
gregory - Replica
Hello, where you able to purchase this from a website? regards Gareth
gareth mccombe -
is there a website where i can buy the circuit?
UsuelTundra1994 - Replica
Hello do you sale replace my parts?
gareth mccombe - Replica
Where can one purchase this circuit board? Haven't been able to locate one anywhere.
David Morrison - Replica
wo und wie kann ich den ganzen Platine kaufen
Hamed Nik - Replica
i need the bottom board, can i know the cost
Lakshmanan Annamalai - Replica
Hey there, I also require the bottom circuit board for my Bose Revolve at India, lakshmanan1413@gmail.com
Looking for a usb charging port for a bose revolve bluetooth speaker.
Kenworth Charles - Replica
Is it possible to add a high resolution closeup of both sides of the PCB please? I have one for repair, and it is missing components, but I am unable to find out the ratings of the missing components.
Kristian Roberts - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 122
Tutti i Tempi: 13,943
