Salta al contenuto principale
Bose Soundlink Revolve Bottom Circuit Board Replacement
Cosa ti serve
  1. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: passo 1, immagine 1 di 2 Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: passo 1, immagine 2 di 2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
    Chiedi a FixBot
    Aggiungi Commento
  2. Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 2, immagine 1 di 3 Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 2, immagine 2 di 3 Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 2, immagine 3 di 3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
    Chiedi a FixBot
    Aggiungi Commento
  3. Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 3, immagine 1 di 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 3, immagine 2 di 2
    • Remove the screw that is above the charging port.
    Chiedi a FixBot
    Aggiungi Commento
  4. Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 4, immagine 1 di 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: passo 4, immagine 2 di 2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
    Chiedi a FixBot
    Aggiungi Commento
  5. Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: passo 5, immagine 1 di 3 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: passo 5, immagine 2 di 3 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: passo 5, immagine 3 di 3
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
    Chiedi a FixBot
    Aggiungi Commento
  6. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board: passo 6, immagine 1 di 1
    • Remove the yellow tape over the location where the ribbon from the central speaker meets the bottom circuit board.
    • Use the blue plastic opening tool to pry up the black latch holding down the ribbon.
    • Remove the motherboard from the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
USF Tampa, Team S6-G2, Remmell Fall 2017 Membro di USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Membri
4 guide realizzate
43Commenti sulla guida
I need the ribbon because it is damage, can you sell one to me?
My email is ttegil@hotmail.com can you send me the way I can buy it.
Kind regards
Gilberto - Rispondi Condividi
Hello do toi fond thé ribbon because i have thé same problème .
M'y email adresse thualromain44.rt@gmail.com
Thanks you
romain thual - Rispondi Condividi
Hi I need bottom circuit board for bose revolve , could you sale it for me. mail: seawolf1974@mail.ru , delivery to Spain
kindly regards
seawolf1974 - Rispondi Condividi
I need bottom circuit board for Bose revolve, can I get it available in Nigeria, @sullivaniheme@gmail.com
Sullivan - Rispondi Condividi
Hey there, I also require the bottom circuit board for my Bose Revolve sam.rowlands@hotmail.com
Sam - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 31
Ultimi 30 giorni: 125
Tutti i Tempi: 17,718
