Salta al contenuto principale
Bose Soundlink Revolve AUX/USB Port Replacement
Cosa ti serve
  1. Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: passo 1, immagine 1 di 2 Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: passo 1, immagine 2 di 2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve AUX/USB Port Replacement: passo 2, immagine 1 di 3 Bose Soundlink Revolve AUX/USB Port Replacement: passo 2, immagine 2 di 3 Bose Soundlink Revolve AUX/USB Port Replacement: passo 2, immagine 3 di 3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
    These are not the screws I have in my bose speaker. These are standard TORX screws ( with 6 sides) bose uses a special 5 sided secure torx screw(with a dot in the middle of the hole). A screwdriver or a screw-bit for these screws is very hard to find. I am still searching for one
    Frank - Replica
  3. Bose Soundlink Revolve AUX/USB Port Replacement: passo 3, immagine 1 di 2 Bose Soundlink Revolve AUX/USB Port Replacement: passo 3, immagine 2 di 2
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve AUX/USB Port Replacement: passo 4, immagine 1 di 2 Bose Soundlink Revolve AUX/USB Port Replacement: passo 4, immagine 2 di 2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: passo 5, immagine 1 di 3 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: passo 5, immagine 2 di 3 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: passo 5, immagine 3 di 3
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
    Where do you buy the usb/ aux port .
    kepac - Replica
    I have a charging cradle and it still flashes red light not charging
    kepac - Replica
    Where do I find this part?
    Bohdan Tomanek (emerysteele) - Replica
    So maybe you have to work at Bose to get the part?
    John Halvorsen - Replica
    Hi! Where do I find this part?
    mariajoseespinoza.m - Replica
    Where can I find this part
    Allan Wilson - Replica
    I just wanted to find out if any android port can be connected and work or they are specific. Also when hot wiring the cables, is there a particular pattern or anything goes?
    Obbo Benjamin - Replica
    How does one reattach the latch here exactly?
    andrewpalozzo - Replica
    Bonjour, ces explications sont très claires mais il reste beaucoup à démonter et surtout on ne sait pas trouver la pièce défectueuse, sans parler d'en trouver une de rechange... Merci quand même mais le chemin est encore long pour réparer cet appareil...
    Henri - Replica
    I suppose if you could open that thing, which might be hard (every smartphone today :D) to impossible without destructing the whole thing (eg Apple usb 3.0 camera adapter) - I haven’t tried it yet -, it’s an easy thing to desolder the ports and replace them with some from eBay or any other platform to buy stuff.
    Daniel Ullrich - Replica
Conclusione
Altre 14 persone hanno completato questa guida.
Brian Butner
Membro da: 09/27/17
804 Reputazione
3 Guide realizzate
USF Tampa, Team S6-G2, Remmell Fall 2017 Membro di USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Membri
4 Guide realizzate
17 Commenti
Any idea where I can find the USB/Aux board for sale?
Chad - Replica
Did you ever manage to find a place to buy it?
Steve Fantin -
You can buy a charging cradle for this device, maybe that helps..
adsf -
Try buying the wireless charger for $29: https://www.bose.com/en_us/products/spea...
Reynolds Cameron -
I am also looking for the usb port replacement part.
James Nowicki - Replica
Anybody have any luck finding the port replacement part?
Andrew Heeter - Replica
woher bekomme ich das USB/AUX board??
codo3
Günter - Replica
Das frage ich auch wo kann man das kaufen. Danke für Info
Elvis Catic -
Got it out but can’t find where to buy replacement aux/usb port
Mark - Replica
Hi! Did you find where to buy It? I would like to replacement It.
Looks like this part is unobtainium from Bose. The PCB underneath has exposed connections. Some one could hack-up something. Maybe a hardwired cable.
Chris - Replica
anyone know which 3rd part parts might work to replace this? not sure exactly what to search for, aux and mini USB to board parts?
Alec McWilliam - Replica
I am also looking for the usb / aux port replacement part.
David Seldes - Replica
Thanks
Malo Le Coz - Replica
@iFixit;
Do you have any suggestions here ?
The same thing happened with my unit ~ it seems there is some kind of cheap piece being used because I was very careful with my speakers. USB port is broken also
Security screws in the bottom of my impossible to get it, took me months to get it out
Base have no because assistance or parts
It’s pretty disgraceful considering the amount is cost and zero support
Any help would be amazing
Cheers
Alan Gibson - Replica
Wo kann man das Teil bestellen?
mg.steiermark - Replica
Helpful, but for most people, a moot fix, since can buy a wireless charger for under $30… https://www.bose.com/en_us/products/spea...
Reynolds Cameron - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 388
Tutti i Tempi: 31,092
