Salta al contenuto principale
Bose Soundlink II Speaker Replacement
Cosa ti serve
  1. Bose Soundlink II Speaker Replacement, Bose Soundlink II Cover Removal: passo 1, immagine 1 di 1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Speaker Replacement: passo 2, immagine 1 di 1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Speaker Replacement, Side Cover: passo 3, immagine 1 di 1
    • Remove the black electrical tape in order to reveal the screws attaching the side cover to the main body of the speaker. These screws are on the base of the device.
  4. Bose Soundlink II Speaker Replacement: passo 4, immagine 1 di 1
    • Using the T-10 star tip screwdriver, remove the two 13 mm screws located on the bottom of the speaker on each side of the battery pack.
  5. Bose Soundlink II Speaker Replacement: passo 5, immagine 1 di 3 Bose Soundlink II Speaker Replacement: passo 5, immagine 2 di 3 Bose Soundlink II Speaker Replacement: passo 5, immagine 3 di 3
    • Slide the silver side cover down toward the base of the speaker. The silver cover will come off easily.
  6. Bose Soundlink II Speaker Replacement, Button Cover: passo 6, immagine 1 di 1
    • Once the Bose Soundlink II Side Covers Removal has been completed, remove the two screws (13 mm) an inch below the buttons on the back of the speaker using the T-10 star tip screwdriver.
  7. Bose Soundlink II Speaker Replacement: passo 7, immagine 1 di 1
    • Using a tool such as a spudger or plastic opening tool, insert the end into one of the small indentations located on the back of the speaker. Start either on the indentation farthest to the right or to the left.
    • Pry up with the spudger or plastic opening tool so that the cover is pushed up slightly.
  8. Bose Soundlink II Speaker Replacement: passo 8, immagine 1 di 1
    • Repeat this process with each of the indentations, working your way left or right (depending on where you start).
  9. Bose Soundlink II Speaker Replacement: passo 9, immagine 1 di 1
    • Pull the cover around the buttons off. If you’d like, you can remove the button cover as well.
  10. Bose Soundlink II Speaker Replacement, Speaker: passo 10, immagine 1 di 2 Bose Soundlink II Speaker Replacement, Speaker: passo 10, immagine 2 di 2
    • Pull the metal grill off of the speaker.
  11. Bose Soundlink II Speaker Replacement: passo 11, immagine 1 di 1
    • Using the T-10 star tip screwdriver, unscrew the four 13 mm screws around each of the speakers.
  12. Bose Soundlink II Speaker Replacement: passo 12, immagine 1 di 1
    • Lift off the cover. (You may need to pry it open)
  13. Bose Soundlink II Speaker Replacement: passo 13, immagine 1 di 2 Bose Soundlink II Speaker Replacement: passo 13, immagine 2 di 2
    • Unwind the wires corresponding to the speaker you want to remove (our photo shows the removal of the top right speaker).
  14. Bose Soundlink II Speaker Replacement: passo 14, immagine 1 di 1
    • Carefully pop out the speaker after the wires have been unwound.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team S3-G3, Harley Spring 2017 Membro di IUPUI, Team S3-G3, Harley Spring 2017
IUPUI-HARLEY-S17S3G3
4 Membri
3 Guide realizzate
3 Commenti
Hello nice tutorial!
Does anyone know where can I find the #357158-0010 Speaker? thanks
zerocool500 - Replica
Does anyone know where to find the #357158-0010 SPEAKER ? Thanks
Thank you ifixit I was able remove the broken aux pin by following these steps..
Ramkaran Rudravaram - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 51
Tutti i Tempi: 6,484
