Salta al contenuto principale
Bose Soundlink II Battery Replacement
Cosa ti serve
  1. Bose Soundlink II Battery Replacement, Bose Soundlink II Cover Removal: passo 1, immagine 1 di 1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  2. Bose Soundlink II Battery Replacement: passo 2, immagine 1 di 1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Bose Soundlink II Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
    Chiedi a FixBot
    Aggiungi Commento
  4. Bose Soundlink II Battery Replacement: passo 4, immagine 1 di 2 Bose Soundlink II Battery Replacement: passo 4, immagine 2 di 2
    • Carefully remove the battery by pulling it out of the speaker.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 18 persone hanno completato questa guida.
Texas Tech, Team 22-4, Rauch Fall 2015 Membro di Texas Tech, Team 22-4, Rauch Fall 2015
TTU-RAUCH-F15S22G4
3 Membri
5 guide realizzate
11Commenti sulla guida
Where i can buy one them battery model?
Daniel Campos - Rispondi Condividi
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
      Thanks, Bob.
bobveitch4 - Rispondi Condividi
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
Okenyodo Johnpaul - Rispondi Condividi
I bought an Replacement battery which brand is Emaks from Amazon and do it following the guide,It works well now!Thank you!!!
Emily - Rispondi Condividi
How much the battery only
Joboy De Guzman II - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 46
Ultimi 30 giorni: 246
Tutti i Tempi: 38,290
