Salta al contenuto principale
Bose SoundTouch Portable Speaker Battery Replacement
Cosa ti serve
  1. Bose SoundTouch Portable Speaker Battery Replacement, Speaker Battery: passo 1, immagine 1 di 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Speaker Battery Replacement: passo 2, immagine 1 di 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Speaker Battery Replacement: passo 3, immagine 1 di 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team S1-G3, Leahy Spring 2017 Membro di USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 Membri
9 Guide realizzate
Un commento
Where did you purchase the battery? Finding a new battery has been more challenging than figuring out how to do it.
Ryan Johnson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 33
Tutti i Tempi: 6,971
