Salta al contenuto principale
Bose SoundTouch 20 Motherboard Replacement
Cosa ti serve
  1. Bose SoundTouch 20 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Bose SoundTouch 20 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Remove the (6) six 1.5mm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
    • Lift the cover straight up and set the cover aside.
    i want the motherboard
    Saleem Al shukairi - Replica
    from where i can get the motherboard?
    I need this mainboard
    yosoymichael - Replica
  2. Bose SoundTouch 20 Motherboard Replacement: passo 2, immagine 1 di 2 Bose SoundTouch 20 Motherboard Replacement: passo 2, immagine 2 di 2
    • Gently pull the white ribbon from the connector on the top side of the power board.
    • Make sure to pull straight back so you don't bend or damage the ribbon.
  3. Bose SoundTouch 20 Motherboard Replacement: passo 3, immagine 1 di 2 Bose SoundTouch 20 Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the (4) four 1.5 cm screws connecting the power board to the speaker.
    • Remove the (2) two 1 cm screws connecting the power board to the speaker.
    • Gently lift the board up.
    • When lifting the board, be careful of the two ribbons located underneath the board. Don't lift the board straight up, instead tilt it towards the cables. As shown in picture 2.
  4. Bose SoundTouch 20 Motherboard Replacement: passo 4, immagine 1 di 2 Bose SoundTouch 20 Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the white cable by pressing on the side of the connector with a tab and pulling backwards.
  5. Bose SoundTouch 20 Motherboard Replacement: passo 5, immagine 1 di 2 Bose SoundTouch 20 Motherboard Replacement: passo 5, immagine 2 di 2
    • Gently pull the thinner white ribbon towards the center of the board.
    • Pull straight down to prevent bending or damaging the ribbon.
    • Squeeze the plastic sides of the plug and pull straight down to remove this ribbon.
    • Remove the motherboard.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S11-G3, Passmore Fall 2017 Membro di USF Tampa, Team S11-G3, Passmore Fall 2017
USFT-PASSMORE-F17S11G3
4 Membri
5 Guide realizzate
7 Commenti
But how do I purchase a new motherboard?
Donald Weber - Replica
Thank you for excellent information and instruction. Can you please send some link to order a new motherboard?
leo.benjamin - Replica
Thank you for the tutorial. How do I purchase a new motherboard ?
benjamin lozano - Replica
Any known place to purchase a replacement board?
Marceli Palak - Replica
Any luck with a place to purchase a replcement board ?
Henry - Replica
Aber wo bekomme ich das neue Motherboard?
DOLF - Replica
MAURICIO MACEDO - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 105
Tutti i Tempi: 7,025
