Introduzione
Use this guide to replace the screen on the front of your device.
Cosa ti serve
Remove the (6) six 1.5 cm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
Lift the cover straight up and set the cover to the side.
Remove the (2) two 1.5 cm screws circled in picture one.
Rotate the speaker to its side and remove the (2) two 1.5 cm screws circled in picture 2. Remove these screws on either side of the speaker.
After all screws are removed, gently remove the cover from the speaker as shown in picture 3.
Altre 4 persone hanno completato questa guida.
2 Commenti
What symptoms? Is it only the display no longer working or does the whole system not power up?
