Salta al contenuto principale
Bose SoundTouch 10 Bass Port Replacement
Cosa ti serve
  1. Bose SoundTouch 10 Bass Port Replacement, Front Panel: passo 1, immagine 1 di 1
    • Turn the speaker over so that the rubber strips along the bottom are facing you.
    • Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
  2. Bose SoundTouch 10 Bass Port Replacement: passo 2, immagine 1 di 1
    • Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
  3. Bose SoundTouch 10 Bass Port Replacement: passo 3, immagine 1 di 2 Bose SoundTouch 10 Bass Port Replacement: passo 3, immagine 2 di 2
    • Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
    • Lift the panel away to reveal the speaker head.
  4. Bose SoundTouch 10 Bass Port Replacement, Back panel: passo 4, immagine 1 di 1
    • Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
  5. Bose SoundTouch 10 Bass Port Replacement: passo 5, immagine 1 di 1
    • Flip the speaker onto its back.
    • Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
  6. Bose SoundTouch 10 Bass Port Replacement: passo 6, immagine 1 di 2 Bose SoundTouch 10 Bass Port Replacement: passo 6, immagine 2 di 2
    • Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
    • If the panel does not come free easily, a heat gun may be needed to weaken the adhesive.
    • Once the panel has been disconnected, it should fall open revealing the motherboard.
  7. Bose SoundTouch 10 Bass Port Replacement: passo 7, immagine 1 di 2 Bose SoundTouch 10 Bass Port Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use ESD Safe Tweezers (Blunt Nose) to pull out the wire ribbon at the end of the motherboard.
  8. Bose SoundTouch 10 Bass Port Replacement: passo 8, immagine 1 di 2 Bose SoundTouch 10 Bass Port Replacement: passo 8, immagine 2 di 2
    • The motherboard contains capacitors (shown as cylinders in the upper right of the picture) which can hold a charge even when the speaker is powered off. Do not touch them as doing so may result in a shock.
    • Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
  9. Bose SoundTouch 10 Bass Port Replacement, Bass Port: passo 9, immagine 1 di 1
    • Use a #0 Phillips screwdriver to remove each of the two 11mm screws attached to the bass port.
  10. Bose SoundTouch 10 Bass Port Replacement: passo 10, immagine 1 di 1
    • Lift the bass port away from the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S13-G1, Forte Spring 2017 Membro di Cal Poly, Team S13-G1, Forte Spring 2017
CPSU-FORTE-S17S13G1
4 Membri
5 Guide realizzate
Un commento
I whant purchase capacitor 330
35v
Chandan Kumar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,766
