Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Use this guide to replace the front or back mesh grilles. Make sure you have the required tools. The first time you remove a grille might be a little difficult due to some glue holding it in place. Be careful when removing, as the grille may bend easily.
Parti
Nessuna parte specificata.
  1. Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
    Woher bekomme ich nun rin solches Vorder- und Rückgitter?
    [COBS]CR4ZY BLITZ - Replica
  2. Slowly pry up the grille until the two tabs shown pop out. Be very gentle, the grille will bend.
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right. Be very gentle, the grille will bend.
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Repeat steps to remove the back grille. Repeat steps to remove the back grille.
    • Repeat steps to remove the back grille.
Conclusione
Altre 8 persone hanno completato questa guida.
Jordan Smith
Membro da: 01/10/2015
785 Reputazione
4 Guide realizzate
Cal Poly, Team 1-23, Maness Fall 2015 Membro di Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Membri
15 Guide realizzate
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - Replica
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - Replica
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 77
Tutti i Tempi: 9,168
