Salta al contenuto principale
Bose SoundLink Mini Front/Back Protective Grille Replacement
Cosa ti serve
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: passo 1, immagine 1 di 1
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 2, immagine 1 di 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 2, immagine 2 di 2
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 3, immagine 1 di 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 3, immagine 2 di 2
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 4, immagine 1 di 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 4, immagine 2 di 2
    • Repeat steps to remove the back grille.
Conclusione
Altre 10 persone hanno completato questa guida.
Cal Poly, Team 1-23, Maness Fall 2015 Membro di Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Membri
21 Guide realizzate
6 Commenti
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - Replica
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - Replica
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - Replica
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 79
Tutti i Tempi: 13,549
