Salta al contenuto principale
Bose SoundLink Mini Battery Cover Replacement
Cosa ti serve
  1. Bose SoundLink Mini Battery Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
  2. Bose SoundLink Mini Battery Cover Replacement: passo 2, immagine 1 di 2 Bose SoundLink Mini Battery Cover Replacement: passo 2, immagine 2 di 2
    • While holding the cover back, pull straight up on the battery to remove it.
  3. Bose SoundLink Mini Battery Cover Replacement, Front/Back Protective Grille: passo 3, immagine 1 di 1
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  4. Bose SoundLink Mini Battery Cover Replacement: passo 4, immagine 1 di 2 Bose SoundLink Mini Battery Cover Replacement: passo 4, immagine 2 di 2
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  5. Bose SoundLink Mini Battery Cover Replacement: passo 5, immagine 1 di 2 Bose SoundLink Mini Battery Cover Replacement: passo 5, immagine 2 di 2
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  6. Bose SoundLink Mini Battery Cover Replacement: passo 6, immagine 1 di 2 Bose SoundLink Mini Battery Cover Replacement: passo 6, immagine 2 di 2
    • Repeat steps to remove the back grille.
  7. Bose SoundLink Mini Battery Cover Replacement, Battery Cover: passo 7, immagine 1 di 2 Bose SoundLink Mini Battery Cover Replacement, Battery Cover: passo 7, immagine 2 di 2
    • Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
  8. Bose SoundLink Mini Battery Cover Replacement: passo 8, immagine 1 di 2 Bose SoundLink Mini Battery Cover Replacement: passo 8, immagine 2 di 2
    • Remove the circuit board by pushing it with your index finger in the direction shown while using a nylon or metal spudger to lift it up and out of place.
  9. Bose SoundLink Mini Battery Cover Replacement: passo 9, immagine 1 di 2 Bose SoundLink Mini Battery Cover Replacement: passo 9, immagine 2 di 2
    • Carefully pull on the battery cover until the rubber tab slides out of the aluminum casing.
Conclusione
Altre 7 persone hanno completato questa guida.
Cal Poly, Team 1-23, Maness Fall 2015 Membro di Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Membri
21 Guide realizzate
3 Commenti
can someone tell me how do i reattach the rubber battery cover if i have removed it completely
rajpotus - Replica
Cut the lip off. You will not be able to put it back. It’s Bose’s terrible design.
megaspeed - Replica
@rajpotus: I had the same problem. If the little rubber tab is not damaged (mine was fine), you should be able to follow these instructions to replace it. But I have these comments on the instructions:
1) You do NOT need to remove the front grill. I have no idea why they suggest you do that here.
2) I think the reason you remove the battery is to make sure the circuit board has zero power on it when you work on it — otherwise a touch of the screwdriver to an unlucky spot on the board might short/burn something out. But I don’t think there’s any mechanical reason to remove it.
3) Once you pop off the back grill cover, you should be able to slide the tab through the slot and coax it up (maybe with a tooth-pick and/or tweezers) on top of the circuit board, but it’s probably better to unscrew the circuit board (as directed here) which makes it easier to push the rubber tab through. Then slide the circuit board back under the tab and screw it back into place.
Matthew Busche - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 54
Ultimi 30 Giorni: 186
Tutti i Tempi: 16,256
