Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will show how to remove the 4 screws that are holding the two parts of the casing together and how to separate the casing for replacement.
  1. Four round, plastic plugs are located on the back of the device. Using a metal spudger, carefully pry up the plastic covers.
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
    hi i just finished prying apart those round buttons. it is very important to know if you dont want to mangle the button trying to pry it loose. if your looking down at the four buttons the inside part of all the four round circles is where you put a thin small tool, that is where the opening is to eventually pull up the whole thing without having to mangle the circle. so if your looking at the four circles the opening will be in the part of circle where all rounds face each other inward i hope this helps
    art - Replica
    Note that the torx plus is a 5 star tool, and was the size 15 for me. Make sure you don't purchase the common 6 sided star tool.
    Mark - Replica
    Knowing you have to replace battery, why are the %#*@ things glued on? Just sayin’
    Toni - Replica
    Knowing battery needs to be replaced, why are these things glued??
    Toni - Replica
    Not a tool to remove! Why’re they glued in the first place?
    Toni - Replica
    I’ve ruined perfectly good tools!
    Toni - Replica
    This has become stupid! Posting comments that never appear!
    Toni - Replica
    Should be effing impossible!
    Toni - Replica
    Sorry, just now found them! Honestly, this can become impossible!
    Toni - Replica
    I found it not possible to remove the screw caps cleanly, without messing up the case around the caps. Here’s a new method. This method damages the screw caps, but it keeps the case from getting mangled.
    1. Use a spring-loaded center punch to emboss a small dimple in the center of each screw cap.
    2. Drill a hole (using a 1/8th-inch bit) in each cap, using the aforementioned dimple to center the bit.
    3. Use a small screwdriver shaft to pry out each screw cap, working each cap gently up and out, in a circular motion.
    NOTE: The prying action (not to mention the hole you just drilled) will damage the screw caps enough that you probably will end up just tossing them. They serve no functional purpose other than to make replacing the battery more challenging. (Thanks Bose!)
    If you do elect to re-install the screw caps, note that they’re keyed uniquely (in pairs). They are not interchangeable.
    I tossed mine.
    Riccardo - Replica
    There is no such animal as a 1.8 cm Torx plus bit. A great site made poor with misleading information. Boo hoo
    phpeh - Replica
  2. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  3. Remove the four 1.8 cm Torx Plus TR screws from the outer case. Remove the four 1.8 cm Torx Plus TR screws from the outer case.
    • Remove the four 1.8 cm Torx Plus TR screws from the outer case.
    the torque sizing bit would be the number 5 torque bit which will fit in the screw to unscrew it
    art - Replica
    My experience required a number 15 torx plus head.
    This was a 5 sided star, not a 6 sided star.
    Mark - Replica
    It's NOT torx plus. It's torx SECURITY. Torx Plus is designed for high torque situations. The bit with the hole in the middle is Torx Security.
    Dennis Lupatsky - Replica
    So what size Torx Security bit is needed for this task please and thank you
    Cobb Adams -
    Ok,how much more complicated can this get?
    Toni - Replica
    Disappointed the Pro Tech Toolkit didn’t include the tip I needed. However I would like to know how to buy a 1.8 tip. The link you give in the list of tools needed takes me to a product on Amazon which includes 10, 15, 20 tips. I’d assume a 1.8 cm would be an 18?
    mark thornburg - Replica
    1,8 cm is the length of the screw. Security Torx f a center pin, so you need a tip with a corresponding hole. Try 10, 15 or 20.
    VauWeh -
    1,8 cm is the length of the screw. Security Torx feature a center pin, so you need a tip with a corresponding hole. Try 10, 15 or 20.
    VauWeh - Replica
  4. Carefully open up the casing. The top button pad may need to be re-glued upon installing the new casing.
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
Conclusione
Altre 11 persone hanno completato questa guida.
When I search for a 1.8 cm Torx Plus TR drill bit, I see a whole set from Amazon. Is there a particular number or head size just so I can purchase one drill bit?
jwm82 - Replica
Hey, did you find out what size screwdriver you need?
kestis155 -
yes its the number 5 torque
art -
dose anyone know where to buy the outer casing for these? i need a mint colored one.
idixon16 - Replica
I need more information on the Torx Plus bit can you provide the exact size as you used. The 1.8cm is not easy to search for. Brand and exact size number would help.
Joseph - Replica
yes its the number 5 torque to fit the screw perfectly
art -
Can we get some details on the battery, like dimensions, mAh, voltage? Hopefully it isn't some proprietary thing, I still can't even get my screw covers off, Bose really prefers we all purchase new ones instead of repair it. I have used all of my various spudgers and iSesame's, maybe I have to hot glue a chop stick in the middle of each cover and pull them off like that? Hard to get leverage in those tiny crevices.
Matt - Replica
did anyone ever figure out where to buy the housing/casing?
Humair Madhani - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 91
Ultimi 30 Giorni: 311
Tutti i Tempi: 19,305
