Salta al contenuto principale
Introduzione
When one or all of the buttons stop working on a device, it can be a frightening thing. Use this guide to help.
  1. Four round, plastic plugs are located on the back of the device. Using a metal spudger, carefully pry up the plastic covers.
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
    hi i just finished prying apart those round buttons. it is very important to know if you dont want to mangle the button trying to pry it loose. if your looking down at the four buttons the inside part of all the four round circles is where you put a thin small tool, that is where the opening is to eventually pull up the whole thing without having to mangle the circle. so if your looking at the four circles the opening will be in the part of circle where all rounds face each other inward i hope this helps
    art - Replica
    Note that the torx plus is a 5 star tool, and was the size 15 for me. Make sure you don't purchase the common 6 sided star tool.
    Mark - Replica
    Knowing you have to replace battery, why are the %#*@ things glued on? Just sayin’
    Toni - Replica
    Knowing battery needs to be replaced, why are these things glued??
    Toni - Replica
    Not a tool to remove! Why’re they glued in the first place?
    Toni - Replica
    I’ve ruined perfectly good tools!
    Toni - Replica
    This has become stupid! Posting comments that never appear!
    Toni - Replica
    Should be effing impossible!
    Toni - Replica
    Sorry, just now found them! Honestly, this can become impossible!
    Toni - Replica
  2. Remove the four 1.8 cm Torx Plus TR screws from the outer case. Remove the four 1.8 cm Torx Plus TR screws from the outer case.
    • Remove the four 1.8 cm Torx Plus TR screws from the outer case.
    the torque sizing bit would be the number 5 torque bit which will fit in the screw to unscrew it
    art - Replica
    My experience required a number 15 torx plus head.
    This was a 5 sided star, not a 6 sided star.
    Mark - Replica
    It's NOT torx plus. It's torx SECURITY. Torx Plus is designed for high torque situations. The bit with the hole in the middle is Torx Security.
    Dennis Lupatsky - Replica
    So what size Torx Security bit is needed for this task please and thank you
    Cobb Adams -
    Ok,how much more complicated can this get?
    Toni - Replica
    Disappointed the Pro Tech Toolkit didn’t include the tip I needed. However I would like to know how to buy a 1.8 tip. The link you give in the list of tools needed takes me to a product on Amazon which includes 10, 15, 20 tips. I’d assume a 1.8 cm would be an 18?
    mark thornburg - Replica
    1,8 cm is the length of the screw. Security Torx f a center pin, so you need a tip with a corresponding hole. Try 10, 15 or 20.
    VauWeh -
    1,8 cm is the length of the screw. Security Torx feature a center pin, so you need a tip with a corresponding hole. Try 10, 15 or 20.
    VauWeh - Replica
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Carefully open up the casing. The top button pad may need to be re-glued upon installing the new casing.
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
  5. Lift up the retaining flap on the button cable ZIF connector. Pull the button cable straight out of the connector.
    • Lift up the retaining flap on the button cable ZIF connector.
    • Pull the button cable straight out of the connector.
  6. Carefully pull the ribbon cable through the rubber gasket that runs around the device. Carefully pull the ribbon cable through the rubber gasket that runs around the device.
    • Carefully pull the ribbon cable through the rubber gasket that runs around the device.
  7. To remove the old rubber button pad, carefully peel it off of the blue casing.
    • To remove the old rubber button pad, carefully peel it off of the blue casing.
Conclusione
To reassemble your device, follow these instructions in reverse order, starting from Step 6.
Altre 6 persone hanno completato questa guida.
Great guide, and I think I can manage this. But, where can I get the Replacement Bose SoundLink Color Button Pad??
Fred
Fred Fish - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 123
Tutti i Tempi: 5,805
