Salta al contenuto principale
Bose SoundDock XT Logic Board Replacement
Cosa ti serve
  1. Bose SoundDock XT Logic Board Replacement, Logic Board: passo 1, immagine 1 di 1
    • Remove the six # 1 Phillips head screws from the bottom panel.
  2. Bose SoundDock XT Logic Board Replacement: passo 2, immagine 1 di 1
    • After removing the bottom plate, you will have visibility of the logic board. Using a plastic opening tool, lift the small black latch holding the ribbon cable. Slide the ribbon cable loose from the logic board.
  3. Bose SoundDock XT Logic Board Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Next, using pointed nose tweezers, remove the 4-wire white connector from the logic board by wiggle back and forth while lifting until the connector is disconnected from the board.
    • Metal pointed nose tweezers may cause damage if used improperly.
  4. Bose SoundDock XT Logic Board Replacement: passo 4, immagine 1 di 1
    • Remove the remaining 8mm length # 2 Phillips head screws holding the motherboard in place.
  5. Bose SoundDock XT Logic Board Replacement: passo 5, immagine 1 di 2 Bose SoundDock XT Logic Board Replacement: passo 5, immagine 2 di 2
    Desoldering Pump
    $3.99
    Compra
    • Record the order of the 6 wires soldered to the board.
    • Using a hot soldering iron and either a solder sucker or de-soldering wick, remove the solder from the 6 wires highlighted on the photo in red.
    • Soldering iron may cause damage to the device if used improperly.
  6. Bose SoundDock XT Logic Board Replacement: passo 6, immagine 1 di 1
    • Replace old logic board with the new logic board. Place the wires into the solder holes and solder in place. Reassemble the SoundDock.
    • Make sure the wires are in the correct order using the recorded pattern from the wire removal step 3.
Conclusione
To reassemble your device, follow these instructions in reverse order. With proper execution of these steps, you will be able to replace your logic board and enjoy the sound of your SoundDock XT.
Altre 4 persone hanno completato questa guida.
redacted
Membro da: 09/29/15
288 Reputazione
2 Guide realizzate
IUPUI, Team 1-4, Hagerty Fall 2015 Membro di IUPUI, Team 1-4, Hagerty Fall 2015
IUPUI-HAGERTY-F15S1G4
5 Membri
3 Guide realizzate
Un commento
Hi, one question, where can i buy the replacement logic board?
Nahir Romero - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,179
