Salta al contenuto principale
Bose SoundDock Portable v2 Remote Battery Replacement
Cosa ti serve
  1. Bose SoundDock Portable v2 Remote Battery Replacement, Remote Battery: passo 1, immagine 1 di 1
    • Using a quarter, turn the battery cover 1/8th of a turn counterclockwise.
  2. Bose SoundDock Portable v2 Remote Battery Replacement: passo 2, immagine 1 di 2 Bose SoundDock Portable v2 Remote Battery Replacement: passo 2, immagine 2 di 2
    • Remove cover and battery. The new battery should be placed with the positive (flat) side facing up.
    • The correct battery for your remote is a CR2032. You may also use a DL2032.
Conclusione
Cal Poly, Team 4-1, Maness Spring 2015 Membro di Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Membri
5 Guide realizzate
Un commento
We have a Bose Wave radio w/remote. This remote is not the one shown here with a screw for the battery compartment. It's the type w/a sliding holder for the battery on the south end (bottom of the battery). Someone went to replace the battery and shoved the holder in upside down I believe. Consequently the holder will not come out all the way.
There must be a way to get it out without forcing it. There's a pinch clip you have to either squeeze or move to the left to disengage it from the locked position and free it up. Any ideas as to how to accomplish this? We appreciate a reply back so this would make our Christmas better.
Merry Christmas & Happy Holidays! Cheers!
asbirdiesingh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 136
Tutti i Tempi: 13,492
