Salta al contenuto principale
Bose SoundDock Portable v2 IR Receiver Replacement
Cosa ti serve
  1. Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: passo 1, immagine 1 di 3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: passo 1, immagine 2 di 3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: passo 1, immagine 3 di 3
    • Gently pry the front mesh cover off of the sound dock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart.
  2. Bose SoundDock Portable v2 IR Receiver Replacement: passo 2, immagine 1 di 1
    • Using a T15 torx screwdriver, remove the 8mm screw holding the IR sensor to the speaker system.
  3. Bose SoundDock Portable v2 IR Receiver Replacement: passo 3, immagine 1 di 1
    • Using tweezers or your fingers, gently remove the ribbon cable connecting the IR sensor to the system.
    I have bose sound duck portable. Remote are not working I was try to othere remote it's in side the bose spekers in self not working I got new censer still not working what I will it's be mouther brod in side problem any idea how to fixe the remote controls
    Mssu Mssujohn - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Evan Low
Membro da: 04/14/15
551 Reputazione
4 Guide realizzate
Cal Poly, Team 4-1, Maness Spring 2015 Membro di Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Membri
5 Guide realizzate
Un commento
Hi my sounddock blocked suddenly and the green led always on. Do you now something about please... :(
jose - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 6,746
