Salta al contenuto principale
Bose Solo 5 Sound Bar Speaker Replacement
Cosa ti serve
  1. Bose Solo 5 Sound Bar Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Lay Bose Solo 5 on its top side with the speakers facing away from you.
  2. Bose Solo 5 Sound Bar Speaker Replacement: passo 2, immagine 1 di 2 Bose Solo 5 Sound Bar Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the two screws located at the outer edge of the backside with a Phillips head screwdriver.
  3. Bose Solo 5 Sound Bar Speaker Replacement: passo 3, immagine 1 di 1
    • Lay the speaker on its backside with the speakers facing up. Wedge the plastic opening tool into the crack where the protective wire screen meets the housing. Pry apart until you create enough room for your fingers.
  4. Bose Solo 5 Sound Bar Speaker Replacement: passo 4, immagine 1 di 2 Bose Solo 5 Sound Bar Speaker Replacement: passo 4, immagine 2 di 2
    • Pull the screen gently away from the housing to reveal the two speakers with your fingers.
  5. Bose Solo 5 Sound Bar Speaker Replacement: passo 5, immagine 1 di 3 Bose Solo 5 Sound Bar Speaker Replacement: passo 5, immagine 2 di 3 Bose Solo 5 Sound Bar Speaker Replacement: passo 5, immagine 3 di 3
    • Remove the 4 screws in each corner of the speaker to remove it from the housing.
  6. Bose Solo 5 Sound Bar Speaker Replacement: passo 6, immagine 1 di 2 Bose Solo 5 Sound Bar Speaker Replacement: passo 6, immagine 2 di 2
    • Peel back the styrofoam on the speaker & disconnect the yellow & brown wires by sliding them off the receptor.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Well opening the case affect its original sound tuning or will it affect the performance ?
Saket Adhau - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 131
Tutti i Tempi: 13,231
