Salta al contenuto principale
Bose Solo 5 Sound Bar Remote Batteries Replacement
  1. Bose Solo 5 Sound Bar Remote Batteries Replacement, Remote Batteries: passo 1, immagine 1 di 3 Bose Solo 5 Sound Bar Remote Batteries Replacement, Remote Batteries: passo 1, immagine 2 di 3 Bose Solo 5 Sound Bar Remote Batteries Replacement, Remote Batteries: passo 1, immagine 3 di 3
    • Open the battery compartment cover on the back of the remote by applying pressure with fingers and sliding downward.
  2. Bose Solo 5 Sound Bar Remote Batteries Replacement: passo 2, immagine 1 di 1
    • Remove both AA batteries carefully.
  3. Bose Solo 5 Sound Bar Remote Batteries Replacement: passo 3, immagine 1 di 1
    • Look for any battery acid corrosion in the wells and clean with a cotton swab or a dull pointed tool to remove the residue.
    • Insert two AA (IEC-LR6) 1.5V batteries or the equivalent.
    • Match the + and – symbols on the batteries with + and – markings inside the compartment.
  4. Bose Solo 5 Sound Bar Remote Batteries Replacement: passo 4, immagine 1 di 3 Bose Solo 5 Sound Bar Remote Batteries Replacement: passo 4, immagine 2 di 3 Bose Solo 5 Sound Bar Remote Batteries Replacement: passo 4, immagine 3 di 3
    • To reassemble your device, place the cover back over the batteries by lining up the teeth and sliding upward until you hear a click.
Conclusione
We hope this guide was useful to you! Replacing your Bose Solo 5 Soundbar remote batteries should be quick and easy!
Emma
Membro da: 10/05/18
500 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,646
