Salta al contenuto principale
Bose On-Ear headphones Ear Cushion Replacement
Cosa ti serve
  1. Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: passo 1, immagine 1 di 3 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: passo 1, immagine 2 di 3 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: passo 1, immagine 3 di 3
    • Here is the Bose Tricore OE headset. Slightly worn and a torn left ear cushion
    • To remove an existing ear cushion one would simply be applying a bit of force between the ear pads and the housing. The ear cushion will simply snap off
    • This shows the snaps that attach the ear pad to the case.
  2. Bose On-Ear headphones Ear Cushion Replacement: passo 2, immagine 1 di 3 Bose On-Ear headphones Ear Cushion Replacement: passo 2, immagine 2 di 3 Bose On-Ear headphones Ear Cushion Replacement: passo 2, immagine 3 di 3
    • Since the ear cushion was already torn off on this one, simply clean the mating surfaces from all debris left by the old ear cushion
    • All left over foam and adhesive tape needs to be removed. This will ensure a proper fit.
    • Here is a look at the back of the replacement cushion.
  3. Bose On-Ear headphones Ear Cushion Replacement: passo 3, immagine 1 di 3 Bose On-Ear headphones Ear Cushion Replacement: passo 3, immagine 2 di 3 Bose On-Ear headphones Ear Cushion Replacement: passo 3, immagine 3 di 3
    • Position the cushion so that the orientation aligns the two holes with the two pins on the headphones.
    • Place the new ear cushion on the headphones ensuring the holes and pins are lined up.
    • A simple squeeze on the ear cushion will snap the plastic to the headphones.
  4. Bose On-Ear headphones Ear Cushion Replacement: passo 4, immagine 1 di 1
    • Good as new and ready to jam!
Conclusione
oldturkey03
Membro da: 09/29/10
781.196 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
32 Membri
530 Guide realizzate
Un commento
Thanks for showing the steps
Rajiv Garg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 48
Tutti i Tempi: 7,278
