Salta al contenuto principale
Bosch PS21 Motor Replacement
Cosa ti serve
  1. Bosch PS21 Motor Replacement, Battery: passo 1, immagine 1 di 1
    • Pinch the two release tabs on the sides of the battery, and slide the battery out.
  2. Bosch PS21 Motor Replacement, Motor: passo 2, immagine 1 di 2 Bosch PS21 Motor Replacement, Motor: passo 2, immagine 2 di 2
    • After removing the battery pack, locate the clip that connects the two halves of the outer casing shown in the picture. Remove the clip using angled tweezers or a similar tool. Save the clip for reassembly.
  3. Bosch PS21 Motor Replacement: passo 3, immagine 1 di 1
    • Locate the eight 5.5 mm screws as shown in the picture.
    • Remove each screw using a small Phillips head screw driver. Save all the screws for reassembly.
  4. Bosch PS21 Motor Replacement: passo 4, immagine 1 di 2 Bosch PS21 Motor Replacement: passo 4, immagine 2 di 2
    • Starting at the rear of the drill, use a wedge to separate the two halves of the outer case at the parting line.
  5. Bosch PS21 Motor Replacement: passo 5, immagine 1 di 2 Bosch PS21 Motor Replacement: passo 5, immagine 2 di 2
    • The motor and trigger assembly are connected by two wires. Do not pull or put tension on these wires.
    • Lift up the metal tab as shown in the first picture to free the trigger assembly.
    • Gently dislodge the motor and trigger assembly from the drill case. Remove the components as one piece, shown in the second picture.
  6. Bosch PS21 Motor Replacement: passo 6, immagine 1 di 3 Bosch PS21 Motor Replacement: passo 6, immagine 2 di 3 Bosch PS21 Motor Replacement: passo 6, immagine 3 di 3
    • Be sure to not grip the pliers too firmly, as it could cause damage to the wire connectors.
    • Firmly secure the motor assembly in place. Using a set of pliers, carefully pull the black wire connector away from the motor. Repeat this action with the red wire connector.
    • The wire connections on the motor are color coded, matching the color wire that connects there.
  7. Bosch PS21 Motor Replacement: passo 7, immagine 1 di 3 Bosch PS21 Motor Replacement: passo 7, immagine 2 di 3 Bosch PS21 Motor Replacement: passo 7, immagine 3 di 3
    • Once the wires have been disconnected, separate the trigger mechanism from the motor assembly.
    • Place your hands on each end of mechanism and carefully pull apart the assembly in order to separate the gearbox from the motor.
Conclusione
IUPUI, Team 1-2, Harley Spring 2016 Membro di IUPUI, Team 1-2, Harley Spring 2016
IUPUI-HARLEY-S16S1G2
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,702
