Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Purchase a new On/Off Switch. The sander should be unplugged from any power sources. Make sure you organize the removed screws, so you can reinstall them in the correct location.
Parti
  1. Ensure that the power chord is not plugged into an outlet. Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander. Lift the top cover off the sander.
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top cover off the sander.
  2. Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip  to the motor housing. Lift the cable clip and cord from motor housing. Lift the cable clip and cord from motor housing.
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift the cable clip and cord from motor housing.
  3. Kit cacciaviti Manta
    112 punte per ogni riparazione.
    Upgrade Your Toolbox
  4. Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch. Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch. Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch.
    • Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch.
  5. Remove the gray and purple wires by pulling on the wire terminals. Remove the gray and purple wires by pulling on the wire terminals. Remove the gray and purple wires by pulling on the wire terminals.
    • Remove the gray and purple wires by pulling on the wire terminals.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 245
