Salta al contenuto principale
Bosch 3727DEVS Motor Brushes Replacement
Cosa ti serve
  1. Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: passo 1, immagine 1 di 3 Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: passo 1, immagine 2 di 3 Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: passo 1, immagine 3 di 3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top cover off the sander.
  2. Bosch 3727DEVS Motor Brushes  Replacement: passo 2, immagine 1 di 3 Bosch 3727DEVS Motor Brushes  Replacement: passo 2, immagine 2 di 3 Bosch 3727DEVS Motor Brushes  Replacement: passo 2, immagine 3 di 3
    • Remove the two white wires connected to each motor brush by pulling on the spade terminals.
  3. Bosch 3727DEVS Motor Brushes  Replacement: passo 3, immagine 1 di 3 Bosch 3727DEVS Motor Brushes  Replacement: passo 3, immagine 2 di 3 Bosch 3727DEVS Motor Brushes  Replacement: passo 3, immagine 3 di 3
    • Using the T10 Torx Screwdriver, remove the four 9.7 mm screws securing the motor brushes to the housing.
    • After the screws are removed, both motor brushes can be lifted out of their position by hand.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 994
