Salta al contenuto principale
Bosch 3727DEVS Governor Replacement
Cosa ti serve
  1. Bosch 3727DEVS Governor Replacement, Governor: passo 1, immagine 1 di 3 Bosch 3727DEVS Governor Replacement, Governor: passo 1, immagine 2 di 3 Bosch 3727DEVS Governor Replacement, Governor: passo 1, immagine 3 di 3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top off of the sander.
  2. Bosch 3727DEVS Governor Replacement: passo 2, immagine 1 di 3 Bosch 3727DEVS Governor Replacement: passo 2, immagine 2 di 3 Bosch 3727DEVS Governor Replacement: passo 2, immagine 3 di 3
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift the cable clip and cord from motor housing.
  3. Bosch 3727DEVS Governor Replacement: passo 3, immagine 1 di 1
    • Lift the On/Off switch out of the device
    • Remove the gray and purple wires
  4. Bosch 3727DEVS Governor Replacement: passo 4, immagine 1 di 2 Bosch 3727DEVS Governor Replacement: passo 4, immagine 2 di 2
    • Remove the gray, brown, and clear wires by pulling on the wire terminals.
    • Lift the Governor out of the housing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 558
