Salta al contenuto principale
Boosted Board 1st Generation Skateboard Bearings Replacement
Cosa ti serve
  1. Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: passo 1, immagine 1 di 2 Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: passo 1, immagine 2 di 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Skateboard Bearings Replacement: passo 2, immagine 1 di 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Skateboard Bearings Replacement: passo 3, immagine 1 di 2 Boosted Board 1st Generation Skateboard Bearings Replacement: passo 3, immagine 2 di 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Skateboard Bearings Replacement: passo 4, immagine 1 di 3 Boosted Board 1st Generation Skateboard Bearings Replacement: passo 4, immagine 2 di 3 Boosted Board 1st Generation Skateboard Bearings Replacement: passo 4, immagine 3 di 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: passo 5, immagine 1 di 2 Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: passo 5, immagine 2 di 2
    • Use one finger to pull out the pulley bearing.
    • A good technique is to go around in a circle and lift from underneath the bearing in a carving motion.
  6. Boosted Board 1st Generation Skateboard Bearings Replacement: passo 6, immagine 1 di 3 Boosted Board 1st Generation Skateboard Bearings Replacement: passo 6, immagine 2 di 3 Boosted Board 1st Generation Skateboard Bearings Replacement: passo 6, immagine 3 di 3
    • Use an Allen wrench to apply pressure to the inside edge of the bearing until it pops out
  7. Boosted Board 1st Generation Skateboard Bearings Replacement: passo 7, immagine 1 di 3 Boosted Board 1st Generation Skateboard Bearings Replacement: passo 7, immagine 2 di 3 Boosted Board 1st Generation Skateboard Bearings Replacement: passo 7, immagine 3 di 3
    • Replace bearing by dropping it in the center of the wheel and use a socket wrench to pop in back it place
  8. Boosted Board 1st Generation Skateboard Bearings Replacement: passo 8, immagine 1 di 3 Boosted Board 1st Generation Skateboard Bearings Replacement: passo 8, immagine 2 di 3 Boosted Board 1st Generation Skateboard Bearings Replacement: passo 8, immagine 3 di 3
    • Slide the bearing spacer on to an Allen wrench
    • Align the Allen wrench in the center of the bearing and drop the spacer directly in the middle
    • Repeat Step 7 for placing the bearing in this side of the wheel.
Conclusione
To reassemble your device, follow these directions in reverse order.
Emily Imfeld
Membro da: 10/06/16
532 Reputazione
4 Guide realizzate
Cal Poly, Team 15-7, Livingston Fall 2016 Membro di Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 877
