Salta al contenuto principale
Boosted Board 1st Generation Rear Wheels Replacement
Cosa ti serve
  1. Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: passo 1, immagine 1 di 2 Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: passo 1, immagine 2 di 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Rear Wheels Replacement: passo 2, immagine 1 di 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Rear Wheels Replacement: passo 3, immagine 1 di 2 Boosted Board 1st Generation Rear Wheels Replacement: passo 3, immagine 2 di 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Rear Wheels Replacement: passo 4, immagine 1 di 3 Boosted Board 1st Generation Rear Wheels Replacement: passo 4, immagine 2 di 3 Boosted Board 1st Generation Rear Wheels Replacement: passo 4, immagine 3 di 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
Conclusione
Emily Imfeld
Membro da: 10/06/16
532 Reputazione
4 Guide realizzate
Cal Poly, Team 15-7, Livingston Fall 2016 Membro di Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,269
