Salta al contenuto principale
Boombotix Boombot Mini Speaker Replacement
Cosa ti serve
  1. Boombotix Boombot Mini Speaker Replacement, Speaker: passo 1, immagine 1 di 3 Boombotix Boombot Mini Speaker Replacement, Speaker: passo 1, immagine 2 di 3 Boombotix Boombot Mini Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Twist the front panel of the speaker to the left.
    • Do not try to pry or pop off the front panel.
  2. Boombotix Boombot Mini Speaker Replacement: passo 2, immagine 1 di 3 Boombotix Boombot Mini Speaker Replacement: passo 2, immagine 2 di 3 Boombotix Boombot Mini Speaker Replacement: passo 2, immagine 3 di 3
    • Take out the four screws, then remove the panel that contains the speaker.
  3. Boombotix Boombot Mini Speaker Replacement: passo 3, immagine 1 di 3 Boombotix Boombot Mini Speaker Replacement: passo 3, immagine 2 di 3 Boombotix Boombot Mini Speaker Replacement: passo 3, immagine 3 di 3
    • Take the speaker off of the base.
    • Expose the motherboard and place the speaker next to it.
    • Be careful not to tangle or damage the wires connecting the speaker.
    • This panel will be harder to get off. Use something small such as a card to creat a lip for leverage.
  4. Boombotix Boombot Mini Speaker Replacement: passo 4, immagine 1 di 1
    • Find the connection of the speaker by following the wires.
    • Do not damage the battery. Make sure not to use any metal object to poke around in the device because of possible shock.
  5. Boombotix Boombot Mini Speaker Replacement: passo 5, immagine 1 di 2 Boombotix Boombot Mini Speaker Replacement: passo 5, immagine 2 di 2
    • Now that you have found the wire connection to the motherboard, disconnect it.
    • Pull the wire straight out.
  6. Boombotix Boombot Mini Speaker Replacement: passo 6, immagine 1 di 1
    • Connect the white plug of the new speaker to the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,415
