Strumenti
Parti
Nessuna parte specificata.
On the back of the device, remove the four 3/8" Torx head screws using the T-6 Torx bit.
Use a pair of tweezers or a small, pointed object to gently pull the connector out on both the left and right sides.
Using a spudger or prying tool, lift the connected screen and motherboard straight up to expose the gold-colored antenna taped to the back plate.
Using a spudger or your fingernail, remove the black electrical tape securing the antenna to the black plate.
On the back side of the antenna, use a spudger or your fingernail to remove the transparent tape holding the transformer to the antenna.
Gently pull apart the transformer from the back of the anenna.
