Salta al contenuto principale
Body Cover Removal
Cosa ti serve
    1. Body Cover Removal, Remove back cover: passo 1, immagine 1 di 1
      • Push down on the screw to depress the spring loaded hinge and release the door.
      Chiedi a FixBot
      Aggiungi Commento
    2. Body Cover Removal, Remove bottom cover: passo 2, immagine 1 di 1
      • Remove six 5.3 mm #00 screws.
      • Remove one 3.4 mm #00 screw.
      • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
      Chiedi a FixBot
      Aggiungi Commento
    3. Body Cover Removal, Remove left front cover: passo 3, immagine 1 di 1
      • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
      • Remove one 7.3 mm #00 screw.
      • Remove the remote trigger cover.
      Chiedi a FixBot
      Aggiungi Commento
    4. Body Cover Removal, Remove front cover: passo 4, immagine 1 di 2 Body Cover Removal, Remove front cover: passo 4, immagine 2 di 2
      • Remove two 5.3 mm #00 screw.
      • Gently lift up on the flash housing to help remove the cover if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    5. Body Cover Removal, Remove right front cover: passo 5, immagine 1 di 1
      • Remove two 3.9 mm #00 screws.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Sam Gustafson
Membro da: 09/01/22
14.634 Reputazione
78 guide realizzate
2Commenti sulla guida
Do you know is the leatherette is removable?
cavjer123 - Rispondi Condividi
It should be. I haven't done it but it is a separate piece from the plastic panels. Try applying some isopropyl alcohol along an edge to soften the adhesive, then work a dull scraper underneath. It should come off without too much effort.
Sam Gustafson - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 12
Ultimi 30 giorni: 34
Tutti i Tempi: 842
