Salta al contenuto principale
Blu Studio Selfie Rear Cover Replacement
Cosa ti serve
  1. Blu Studio Selfie Rear Cover Replacement, Rear Cover: passo 1, immagine 1 di 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Rear Cover Replacement: passo 2, immagine 1 di 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
Conclusione
Altre 2 persone hanno completato questa guida.
Stacy Kam
Membro da: 01/20/16
630 Reputazione
5 Guide realizzate
USF Tampa, Team 10-1, Remmell Spring 2016 Membro di USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 285
