Introduzione
This simple guide will assist you in replacing the microphone of your Blu Studio Selfie. This guide will need a little bit of technical background needed. It will help complete the fix faster.
This guide requires soldering to remove the microphone. For information on soldering, take a look at How to Solder and Desolder Connections.
Before you begin, power off your phone and disconnect from the phone charger.
Cosa ti serve
Turn the front of the phone away from you.
Run your fingers along the sides of the phone to identify where the case can be pulled apart.
Identify the crevice at the bottom of the battery.
Gently lift the battery free of the phone.
Remove three 4 mm Phillips #000 screws holding the motherboard in place.
Carefully lift the motherboard from the phone, exposing the microphone soldering connections.
Altre 2 persone hanno completato questa guida.
