Salta al contenuto principale
Blu Studio Selfie Front Facing Camera Replacement
Cosa ti serve
  1. Blu Studio Selfie Front Facing Camera Replacement, Rear Cover: passo 1, immagine 1 di 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Front Facing Camera Replacement: passo 2, immagine 1 di 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Front Facing Camera Replacement, Battery: passo 3, immagine 1 di 2 Blu Studio Selfie Front Facing Camera Replacement, Battery: passo 3, immagine 2 di 2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
  4. Blu Studio Selfie Front Facing Camera Replacement, Midframe: passo 4, immagine 1 di 1
    • Remove all the 4mm Phillips #000 screws from the midframe.
  5. Blu Studio Selfie Front Facing Camera Replacement: passo 5, immagine 1 di 1
    • Insert the spudger between the midframe and the display assembly.
    • Gently pry up the midframe.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. Blu Studio Selfie Front Facing Camera Replacement: passo 6, immagine 1 di 1
    • Where the battery rested before, you will find a small clip that holds down the midframe.
    • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
    • Gently lift up on the clip until it comes free.
    • Remove the midframe from the phone.
  7. Blu Studio Selfie Front Facing Camera Replacement, Front Facing Camera: passo 7, immagine 1 di 3 Blu Studio Selfie Front Facing Camera Replacement, Front Facing Camera: passo 7, immagine 2 di 3 Blu Studio Selfie Front Facing Camera Replacement, Front Facing Camera: passo 7, immagine 3 di 3
    • Use tweezers to lift the black tab on the ZIF connector and pull the ribbon cable out of place.
    • Using a pair of tweezers for assistance, remove the front facing camera from its case.
Conclusione
Altre 3 persone hanno completato questa guida.
Stacy Kam
Membro da: 01/20/16
630 Reputazione
5 Guide realizzate
USF Tampa, Team 10-1, Remmell Spring 2016 Membro di USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 11
Tutti i Tempi: 457
