Salta al contenuto principale
Blu Studio Selfie Battery Replacement
Cosa ti serve
  1. Blu Studio Selfie Battery Replacement, Rear Cover: passo 1, immagine 1 di 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Battery Replacement: passo 2, immagine 1 di 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Battery Replacement, Battery: passo 3, immagine 1 di 2 Blu Studio Selfie Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
Conclusione
Stacy Kam
Membro da: 01/20/16
630 Reputazione
5 Guide realizzate
USF Tampa, Team 10-1, Remmell Spring 2016 Membro di USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,324
