Salta al contenuto principale
Blu Studio HD 6.0 MicroSD Card Replacement
Cosa ti serve
  1. Blu Studio HD 6.0 MicroSD Card Replacement, Rear Case: passo 1, immagine 1 di 1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 MicroSD Card Replacement, Back Panel.: passo 2, immagine 1 di 2 Blu Studio HD 6.0 MicroSD Card Replacement, Back Panel.: passo 2, immagine 2 di 2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 MicroSD Card Replacement: passo 3, immagine 1 di 2 Blu Studio HD 6.0 MicroSD Card Replacement: passo 3, immagine 2 di 2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: passo 4, immagine 1 di 3 Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: passo 4, immagine 2 di 3 Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: passo 4, immagine 3 di 3
    • Find the Micro-SD card slot which is under the right SIM card slot.
    • Line up the gold pins of the Micro-SD card with the pins of the card slot. If pins in the slot are hidden, then insert the Micro-SD card with the "MicroSD" print up and the pins facing the slot.
    • Slide the card into the slot until you either hear a clicking noise or until the card does not move anymore. Do not apply too much force; gently slide it in and stop immediately when it does not move anymore.
  5. Blu Studio HD 6.0 MicroSD Card Replacement, Turn the phone on: passo 5, immagine 1 di 1
    • Your phone should boot up and ask you to format your Micro-SD Card.
    • Format the card and you're good to go.
    • If your phone does not recognize the card, ensure that the gold pins of the card aligned with the gold pins on the phone's Micro-SD slot.
    • If the card is installed correctly, the card may be faulty. If so contact the Micro-SD card manufacturer.
Conclusione
Altre 8 persone hanno completato questa guida.
Alec
Membro da: 09/23/14
617 Reputazione
2 Guide realizzate
USF Tampa, Team 9-1, Blackwell Fall 2014 Membro di USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Membri
8 Guide realizzate
Un commento
Very clear instructions and step by step guidance
Laszlo Tihanyi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 16,340
