Salta al contenuto principale
Blu Studio 5.5 Sub PCBA Replacement
Cosa ti serve
  1. Blu Studio 5.5 Sub PCBA Replacement, Battery: passo 1, immagine 1 di 3 Blu Studio 5.5 Sub PCBA Replacement, Battery: passo 1, immagine 2 di 3 Blu Studio 5.5 Sub PCBA Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the notch to remove the back panel at the lower left corner of the panel.
    • Insert the plastic opening tool or a fingernail into the notch.
    • Apply force upwards until back panel becomes loosened.
  2. Blu Studio 5.5 Sub PCBA Replacement: passo 2, immagine 1 di 2 Blu Studio 5.5 Sub PCBA Replacement: passo 2, immagine 2 di 2
    • Remove the loosened back panel and set aside.
    • Locate the notch to remove the battery.
  3. Blu Studio 5.5 Sub PCBA Replacement: passo 3, immagine 1 di 3 Blu Studio 5.5 Sub PCBA Replacement: passo 3, immagine 2 di 3 Blu Studio 5.5 Sub PCBA Replacement: passo 3, immagine 3 di 3
    • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
    • Remove the battery and set aside.
  4. Blu Studio 5.5 Sub PCBA Replacement, Back Panel Assembly: passo 4, immagine 1 di 2 Blu Studio 5.5 Sub PCBA Replacement, Back Panel Assembly: passo 4, immagine 2 di 2
    • Locate all twelve screws along the back panel:
    • Seven 5mm screws.
    • Five 3.5mm screws.
    • Using a Phillips #000 screwdriver, remove all twelve screws.
  5. Blu Studio 5.5 Sub PCBA Replacement: passo 5, immagine 1 di 3 Blu Studio 5.5 Sub PCBA Replacement: passo 5, immagine 2 di 3 Blu Studio 5.5 Sub PCBA Replacement: passo 5, immagine 3 di 3
    • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
    • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
    • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
    • Remove the panel as if you were turning the page of a book.
  6. Blu Studio 5.5 Sub PCBA Replacement, Sub PCBA: passo 6, immagine 1 di 2 Blu Studio 5.5 Sub PCBA Replacement, Sub PCBA: passo 6, immagine 2 di 2
    • Locate the screw holding down the sub PCBA.
    • Remove the screw using the Phillips #000 screwdriver.
  7. Blu Studio 5.5 Sub PCBA Replacement: passo 7, immagine 1 di 3 Blu Studio 5.5 Sub PCBA Replacement: passo 7, immagine 2 di 3 Blu Studio 5.5 Sub PCBA Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Locate the gold plated cable connecting the sub PCBA to the motherboard.
    • Locate the flex cable connector just above the sub PCBA screw.
    • Using tweezers, detach both cables from the sub PCBA.
  8. Blu Studio 5.5 Sub PCBA Replacement: passo 8, immagine 1 di 2 Blu Studio 5.5 Sub PCBA Replacement: passo 8, immagine 2 di 2
    • Note the red and blue wires connecting the sub PCBA to the speakers.
    • Either the speaker will need to be loosened and removed alongside the sub PCBA or the wires disconnected and resoldered during reassembly.
    • Using tweezers, grab the PCBA and remove gently from assembly.
Conclusione
Alec Coleman
Membro da: 02/28/17
313 Reputazione
3 Guide realizzate
USF Tampa, Team S1-G6, Nance Spring 2017 Membro di USF Tampa, Team S1-G6, Nance Spring 2017
USFT-NANCE-S17S1G6
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 504
