Salta al contenuto principale
Blu Studio 5.5 S Speaker Replacement
Cosa ti serve
  1. Blu Studio 5.5 S Speaker Replacement, Back Casing: passo 1, immagine 1 di 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Speaker Replacement, Applying Pressure: passo 2, immagine 1 di 3 Blu Studio 5.5 S Speaker Replacement, Applying Pressure: passo 2, immagine 2 di 3 Blu Studio 5.5 S Speaker Replacement, Applying Pressure: passo 2, immagine 3 di 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Speaker Replacement, Battery: passo 3, immagine 1 di 3 Blu Studio 5.5 S Speaker Replacement, Battery: passo 3, immagine 2 di 3 Blu Studio 5.5 S Speaker Replacement, Battery: passo 3, immagine 3 di 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Speaker Replacement, Midframe: passo 4, immagine 1 di 3 Blu Studio 5.5 S Speaker Replacement, Midframe: passo 4, immagine 2 di 3 Blu Studio 5.5 S Speaker Replacement, Midframe: passo 4, immagine 3 di 3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Speaker Replacement, Aesthetic Bottom Case: passo 5, immagine 1 di 1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Speaker Replacement: passo 6, immagine 1 di 3 Blu Studio 5.5 S Speaker Replacement: passo 6, immagine 2 di 3 Blu Studio 5.5 S Speaker Replacement: passo 6, immagine 3 di 3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Speaker Replacement, Speaker: passo 7, immagine 1 di 3 Blu Studio 5.5 S Speaker Replacement, Speaker: passo 7, immagine 2 di 3 Blu Studio 5.5 S Speaker Replacement, Speaker: passo 7, immagine 3 di 3
    • The speaker is located on the bottom of the back inner case. To remove it, use a pair of angled tweezers.
    • Use the tweezers to remove the speaker off of the casing.
    • Only put the tweezers in enough to gain leverage.
Conclusione
Cody Dyl
Membro da: 10/27/14
804 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 4-8, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,161
