Salta al contenuto principale
Blu L120 Rear Facing Camera Replacement
Cosa ti serve
  1. Blu L120 Rear Facing Camera Replacement, Remove back panel: passo 1, immagine 1 di 3 Blu L120 Rear Facing Camera Replacement, Remove back panel: passo 1, immagine 2 di 3 Blu L120 Rear Facing Camera Replacement, Remove back panel: passo 1, immagine 3 di 3
    • Remove the cover by lifting the notch towards the bottom of the phone. Use your fingernail to lift it up.
  2. Blu L120 Rear Facing Camera Replacement, Screw Removal: passo 2, immagine 1 di 3 Blu L120 Rear Facing Camera Replacement, Screw Removal: passo 2, immagine 2 di 3 Blu L120 Rear Facing Camera Replacement, Screw Removal: passo 2, immagine 3 di 3
    • Remove these nine screws with a small phillips screwdriver. They are all the same size.
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it .
  3. Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: passo 3, immagine 1 di 3 Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: passo 3, immagine 2 di 3 Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: passo 3, immagine 3 di 3
    • Use the pry tool to gently separate the panel from the frame, starting from the bottom left corner and continue along the edge of the phone.
    • *WARNING* by doing this, you will void the manufacturers warranty.
  4. Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: passo 4, immagine 1 di 3 Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: passo 4, immagine 2 di 3 Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: passo 4, immagine 3 di 3
    • Continue using the pry tool around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Rear Facing Camera Replacement, Camera Removal: passo 5, immagine 1 di 3 Blu L120 Rear Facing Camera Replacement, Camera Removal: passo 5, immagine 2 di 3 Blu L120 Rear Facing Camera Replacement, Camera Removal: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the pry tool to disconnect the camera from the device.
    • Gently lift the camera up and use the tweezers to remove it from the phone.
    • Reinstall the camera. Then follow the guide in reverse to put the phone back together.
Conclusione
Julio
Membro da: 10/25/14
695 Reputazione
6 Guide realizzate
Gateway, Team 1-5, Johnson Fall 2014 Membro di Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 222
