Salta al contenuto principale
Blu L120 MicroSD Card Replacement
Cosa ti serve
  1. Blu L120 MicroSD Card Replacement, Adding additional storage: passo 1, immagine 1 di 2 Blu L120 MicroSD Card Replacement, Adding additional storage: passo 1, immagine 2 di 2
    • Turn off the device, and remove the back cover. Start on the notch above the charging port and lift cover up and gently work around the phone until the back cover is off.
    • Remove the battery.
  2. Blu L120 MicroSD Card Replacement, Adding additional storage: passo 2, immagine 1 di 2 Blu L120 MicroSD Card Replacement, Adding additional storage: passo 2, immagine 2 di 2
    • Insert the media card into the phone. Maximum 32gb micro SD.
    • Reinstall the battery and back cover, and power on your device. Success............. you just added more storage to your phone.
Conclusione
Julio
Membro da: 10/25/14
695 Reputazione
6 Guide realizzate
Gateway, Team 1-5, Johnson Fall 2014 Membro di Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 206
