Salta al contenuto principale
Blu Grand M2 Power Button Replacement
Cosa ti serve
  1. Blu Grand M2  Power Button Replacement, Power Button: passo 1, immagine 1 di 1
    • Using a T2 Torx Screwdriver, remove the two screws from the bottom edge of the phone.
  2. Blu Grand M2  Power Button Replacement: passo 2, immagine 1 di 2 Blu Grand M2  Power Button Replacement: passo 2, immagine 2 di 2
    • Apply the suction tool to the back panel near the bottom edge.
    • Carefully slide the device pick between the back panel and bottom edge.
    • Insert the opening tool into the gap created by the device pick.
    • While holding the suction tool, use the opening tool to gently pry the back panel off.
    • Be Cautious to not damage the phone display and or the inside components while using the pry tool and suction tool.
  3. Blu Grand M2  Power Button Replacement: passo 3, immagine 1 di 1
    • Take the end of the opening tool and push the old power button out of its socket.
    • Remove the old power button.
  4. Blu Grand M2  Power Button Replacement: passo 4, immagine 1 di 1
    • Place the new BLU Grand M2 power button in the socket.
Conclusione
Gateway, Team S1-G3, Luster Fall 2018 Membro di Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Membri
4 Guide realizzate
1Commento della guida
Don’t forget to remove the SIM card
Jonathan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 478
